where did you get you leveling kit put on at?
Old Apr 18, 2008 | 11:32 AM
mikebaby's Avatar
Tire Discounters installed mine when I had my new tires put on. It cost around $112 I believe. The first Tire Discounters that I had this worked out with backed out when I showed up. I called the one by my house and they did it no problem and the tires were $4 cheaper each (which I thought was odd)
mikebaby
Old Apr 18, 2008 | 04:54 PM
Yamaha YZ 250's Avatar
Originally Posted by Tylus
so you're saying you never used 4x4, and somehow these "extreme angles" tore your boot. , the front axles DON'T TURN unless you are using 4x4 (unlike Dodge/Jeep). so you either hit something, or it was a pre-existing defect, not the AS fault
I know the front axles don't turn when not in 4wd, and the only off roading I do driving down gravel roads to get to riding areas. I was just washing my truck and was cleaning off the lower control arms and saw grease all over the arm. I took it inside the garage and the tear was on the backside of the boot.
So I'm not sure what it was, probably not from auto spring kit, but I just did not like the angles of the ball joints and CV angles so I took it off, and of course the tear in the boot. If I ever did do any real off roading, which I do when I go to the beach I would rather have piece of mind not knowing my CV axle are going to go out on me going 45 mph down the beach.
Old Apr 19, 2008 | 08:56 AM
sledger's Avatar
Originally Posted by mengela
drive to walmart/autozone/kragens,
buy the tools and jackstands,
install in walmart parking lot,
clean tools,
return tools,
go get alignment.
Now that's funny stuff right there!!!!!
I went with Hell bent steel leveling 2.5" kit. They came with detailed instructions with pics and specified what tools and socket sizes needed. All for only $69 shipped to my door. and they are heavy duty. Easiest install.
Old Apr 24, 2008 | 05:11 PM
McLovin's Avatar
Let's see some pics of it!
Old Apr 24, 2008 | 05:24 PM
05_sprcrw's Avatar
Yamaha YZ 250
Do you have the as still? If so e-mail me I would love to take it off your hands!
