05 Trailer Light Fuse *quick answer please*
Old Apr 12, 2008 | 01:32 PM
Bdt 1967's Avatar
I have an 05 f-150 I purchased this truck used and have a quick question, I hooked up my boat and tested the lights the brakes, left turn, right turn all work, but the running lights don't work, I tested the pins on the truck and the pin that controls the running lights is not hot when the lights are turned on. (Black w/ white line if i remember right) anyway, do any of you guys know what fuse controls that, my truck didn't come with a manual, and it would take me an eternity to pull all of them out and test them.
Old Apr 12, 2008 | 05:43 PM
07vtgt's Avatar
Fuse location
From my manual, an 05 too it says the relay R201 is the trailer tow park lamps and the fuse is location 10 with a 20 amp fuse. The description for the fuse says "trailer tow back-up lamps relay (pcb1), trailer tow parklamp relay (R201)" hope this solves your problems
Old Apr 12, 2008 | 10:06 PM
Bdt 1967's Avatar
Thanks I will check it tomorrow and let you know what I find.
Old Apr 12, 2008 | 10:52 PM
wlgoble's Avatar
Look here for a diagram....you need to scroll about half way down the page. Its from a 2006 but it matches my 2004, so it should work for your 05 also.
https://www.f150online.com/forums/sh...=184757&page=2
