door handle help
door handle help
i asked this question in the other forum with no response. hopefuly someone here will know.
click https://www.f150online.com/forums/sh...d.php?t=329018
TIA
TIA
Someone broke into my truck and messed the whole lock up. You'll have to remove the door panel and basically start removing bolts. There is one from the side of the door, just remove one of the nickel size caps, and its behind it. Ohh and becareful not to sratch your paint. I would tape up your door by the handle. Its a little tricky but worth not paying $270 to have fixed. I also recomend installing Jimmy Jammerz while your in there. Jimmy Jammerz don't have the best design but should help stop the next mf'er.
If you want a stock handle let me know. I have one with the keyhole and no keypad and one off of the rear of my screw. I also know here one is with the keypad if you want that too.
PM or email me.
