hillbilly deluxe build thread
I've been lurking for a while, and i think it's time to send a teaser your guys' way. the e-fans are going in, and new Bilstein circle track shocks are on, and rims are out for powder coat. I even have a something up my sleeve by way of Matt Hotch (the one from biker build off)
here's the beginning of plenty of pics... (because i know one of you smart ***** will give me that 'this thread is useless without pics')
Originally Posted by Midnight05
looks pretty good, but arent you afraid that the filler will stress crack as the body flexes??? i know i would be. filler is only supposed to be used at a 1/16 inch.
believe it or not, with the new compounds, 1/8" - 3/8" is ok for filler. premier plus or rage gold fillers are so smooth, you don't even use spot filler. the adhesion is far superior to 'bondo'
Originally Posted by nuclearthreat54
Is your sig what your truck looks like now?
Cole - the bar stock filled it in perfectly, and gave enough of a gap for the bondo to bite to. If i did sheet metal, i would've still had to smooth it out with filler. six to one, half dozen to the other i guess.
