Rear suspension creaks/pops/groans
Old Apr 2, 2008 | 09:54 PM
Adam06FX4's Avatar
Registered User
there is basically no way for a leaf to shift unless the pins/bolts are broken. look at the top center of your leaf pack... you will see there is 2 bolts that run right through the leaf pack.
Old Apr 3, 2008 | 02:24 AM
etrevino103186's Avatar
Sorry I should have explained better. I understand what you are saying but I don't understand how the aal could be shifted. The aal is the only one that is misaligned. Is there anyway for me to check without have to disassemble the whole leaf? I used Deep Creep, a lot actually. I also stuck little strips of rubber in between the aal and the last leaf. There is still some creaking noise! I am going to have my roommate drive my truck and I will roll underneath with a mechanics creeper.
Old Apr 3, 2008 | 02:33 AM
Josiah's Avatar
if it is only affected by driving and not bumps lube ur driveshafts u joints
Old Apr 3, 2008 | 02:39 AM
The pin holes aren't close tolerance holes. That means there is a little room for the leaf to shift. A little bit of movement at the center will multiply towards the ends.
Edward, I had issues with those AAL's shifting too. I took a c clamp to bring them back together.
Make sure all the bolts are tight too.
Old Apr 3, 2008 | 03:10 AM
Adam06FX4's Avatar
Registered User
i think i understand what you mean by shifting now. do you mean as in the side is not flush with the rest of the leaves? usually the is a clamp around the leaves the hold them strait and i know that when i usually add a leaf to a truck i heat and unfold this clamp, then add the leaf and there is usually enough room in the clamp for one more leaf. if that has been removed you can fab something up.
Old Apr 3, 2008 | 09:51 AM
Phew that makes me feel better. It is like fractions of an inch, not really a big issue but I just want the noise to stop.
Exactly. If I run my hand along the edge of the leafs near where the aal ends it is sticking out fractions of an inch. The skyjacker aal is unlike the others in that it is shorter. Basically it sits right before the clamps. I borrowed some heavy duty c-clamps from Pat. I am going to jack my truck up and push it back into place. Any other ideas why it would still make the noise? I checked all the bushings they seem fine... The sway arm looks a little worn, but the noise doesn't seem to be coming that far up. I also checked the driveshaft for play, none whatsoever. I doused my whole suspension in deep creep. Thanks for the help guys.
Old Apr 3, 2008 | 03:50 PM
bump, any help?
Old Apr 3, 2008 | 10:03 PM
dlongoria's Avatar
Had the same problem at about 20K miles. Took it to the dealer and they cleaned the springs and shoved grease in between the individual leafs in the spring pack. It started making the noise again at about 34K so I took it back. They told me it was pretty much a normal noise, was not considered to be broken and the only "fix" (which doesn't make sense if it isn't broken) is to lube the leafs. They did this again. Noise stops. Service Writer told me he would do it free w oil changes.
Old Apr 4, 2008 | 01:08 AM
khendrix2374's Avatar
It's your leafs. The dealer replaced mine back when I had a warrenty but it came back.
Whenever I have spare time... about once per month, I'll crawl under there and lube up the leafs. I use a large screw driver to pry the leafs apart and lather them up with grease.. not WD or any other spray stuff.. but nasty grease. It works for a little while, but it'll always come back.
Bad design.
Old Apr 4, 2008 | 01:22 AM
styxnpicks's Avatar
Originally Posted by khendrix2374
Bad design.
right....
its not a bad design its just an old design. leaf springs havnt changed at all in the least 100 years. they are tried and true old school and cheap. newsflash... leaf springs make noise. nothing unusual there. its a truck, not a benz
Old Apr 4, 2008 | 02:03 AM
I guess I am going to try grease. I literally DROWNED the leafs in Deep Creep and White Lithium. I am 99% sure it is the leafs. Pat came by today and we tried somethings. He also got a video he should be posting tomorrow.
I know "it is a truck" but I want it to sound like a 2005 and not a 1955.
The noises don't compromise the integrity of the suspension do they?
Old Apr 4, 2008 | 02:12 AM
Not unless a major part is about to shear off, but I'm sure Pat would notice if something was about to break.
My leafs squeak also, and they are only a few months old. I'm going to have to lube them up soon. I don't hear the noise with the radio on though.
Old Apr 4, 2008 | 11:59 AM
http://www.youtube.com/watch?v=6z9OokutOFU
you can hear it really good at the end
Im almost thinkin its the frame flexing a little, because of the angle its at
Old Apr 4, 2008 | 12:39 PM
Wow, I should quit complaining about my little suspension squeak.
Old Apr 4, 2008 | 01:17 PM
What is it?!
