Where is the paint code located on my truck?
Old Mar 25, 2008 | 12:27 AM
marlin39d's Avatar
I'm getting ready to order a Racemesh grille with painted surround for my truck and I need to figure out where to get the paint code off of my truck for them to paint the surround. (2006 supercab)
The color is black with clearcoat if anyone knows the code off the top of your head.
While your reading my post I might as well ask for some opinions on what you think would look best on a black truck with black surround. Stainless steel (not extremely shiny), elecro-polished (extra shiny), or black powder coat (the stealth look) on the mesh? I'm leaning toward either stainless or black powder coated.
Old Mar 25, 2008 | 12:35 AM
Adam06FX4's Avatar
Registered User
2006 Ford F-Series
Color Color Description Color Code
Arizona Beige Metallic Clearcoat AQ/M6985
Screaming Yellow Clearcoat D6/M7109
Vermillion Clearcoat E4/M6470
Toreador Red Pearl Metallic Clearcoat FL/M6758
Dark Satin Green Metallic Clearcoat FU/M6862
Smokestone Metallic Clearcoat HG
Dark Toreador Red Pearl Clearcoat JL/M6771
True Blue Pri Metallic Clearcoat L2/M7023/M7029
Medium Wedgewood Metallic Clearcoat LD/M6763
Aspen Green Pearl Metallic Clearcoat P5/M7056
Dark Copper Metallic Clearcoat T5
Charcoal Beige Metallic Clearcoat T7
Black Ebony Clearcoat UA/M6373/M6877
Silver Metallic Clearcoat YN/M6505/M6895
Oxford White Clearcoat YZ/M6466
Oxford White Clearcoat Z1/M6887
Silver Metallic Clearcoat Z3/6895
your paint code should be UA. it is located inside the drivers door jam on sticker similar to this in the highlighted area.
Old Mar 25, 2008 | 12:56 AM
long story short on your door jam sticker
Old Mar 25, 2008 | 09:10 AM
Dribone's Avatar
if a paint shop is mixing the color, give them your VIN number. Ford uses different dies in different batches of paint, which is identified by the VIN. using the color code, your mixed paint could be darker or lighter than the actual paint on your truck. (black may be black, but theres 700 different different shades)
in your case, i guess its painted already, so you have no choice. you shouldn't have a problem, but for future reference, now you know.
Old Mar 25, 2008 | 09:41 AM
thenewbreed's Avatar
Originally Posted by Adam06FX4
2006 Ford F-Series
I don't see dark stone. Did my dealer tell me the wrong color name?
Old Mar 25, 2008 | 09:53 AM
Dribone's Avatar
dark stone is charcoal beige.
Old Mar 25, 2008 | 10:15 AM
awwww man dark stone sounds so much better, but thanks
Old Mar 25, 2008 | 10:27 AM
tcope's Avatar
That's okay... my Ford car is Ebony black...
Hey Ford....
Definition: Ebony, The color black
Old Mar 25, 2008 | 01:46 PM
Actually "ebony" is a tree that has black wood.
