Need some torque specs...
Hey guys, I put my AAL's on yesterday and the instructions and my manual don't say what the u-bolts or leaf-eye bolts need to be torqued to. It's an 05 4x4. My search turned up nothing.....
Thanks,
Myren
Thanks,
Myren
Thanks,
Myren
Thanks,
Myren
Description Nm lb-ft
Rear Suspension
Shock absorber, upper 90 66
Shock absorber, lower 90 66
Rear caliper bolts 32 24
U-bolt nuts (light duty) 115 85
U-bolt nuts (heavy duty) 250 184
Spring/frame nut (front) 300 222
Spring/shackle nut (rear) 133 98
Spring shackle/frame nut 133 98
AAL's are add-a-leaf. Basically it's a leaf spring that is put in between the smallest and next largest leaf to give a little lift and help with being overloaded. And yes, it is helpful. Many thanks!
Thanks,
Myren
Thanks,
Myren
Thanks again wrench007! I torqued the u-bolts down and just tightened up the eye bolts when I had the truck back on the ground. I'll re-check in a couple hundred miles, but I don't think that they play that much of a role in keeping everything together.
That's the girl robot I'm working on.......
Originally Posted by freekyFX4
I'm not sure...but who is that girl in your signature?
