Friction Modifier Motorcraft or Amsoil?
Old Mar 24, 2008 | 10:51 AM
jimc2004's Avatar
I will be changing out my rear diff. fluid soon with amsoil 75w-140. I have Limited slip so I will need to add friction modifier. What Friction modifier will allow my LS to perform the best?
Should I use the amsoil friction modifier since I am using amsoil gear oil, or use motorcraft FM since its a Ford truck.
Let me know what you guys think. - Thanks
Old Mar 24, 2008 | 10:55 AM
It doesn't matter...
I recommend:
Additive Friction Modifier - Ford Part # - XL-3.
Old Mar 24, 2008 | 12:54 PM
ThumperMX113's Avatar
Are you sure it doesn't already have a friction modifier in it? I know RP has it in their gear oil already..
Old Mar 24, 2008 | 12:56 PM
Copenhagen848's Avatar
Royal Purple and Lucas are the only gear oils I found in which it comes pre-added.
Old Mar 24, 2008 | 04:14 PM
jimc2004's Avatar
From what I hear is usually best to add it anyways.
I just want to make sure my limited slip still works to its full potential and locks up the correct wheel as much as possible, because I live in MI with bad winters and I off road in the sand dunes often.
Old Mar 24, 2008 | 04:52 PM
openclasspro#11's Avatar
amsoil 7590 sgd here with their additive-locks up perfectly in the winter as designed-phil
btw-rp says it will work in locking differentials but when i asked them if their oil met the specs of ford's additive they said no but they didn't have any issues in fords-phil
Old Mar 24, 2008 | 05:02 PM
I used straight Royal Purple 75w-140 in my truck when I got my 4.88s done and I had no problems with my LSD.
