Wheels, backspacing & pics
Originally Posted by attworth
BS is the measurement from the back to the mounting point, not the true center.
Look at it this way.
8" wheel. 4" backspacing. Say it sits exactly even with the fender.
9" wheel. 4" backspacing. This will be 1" out from the fender.
Stock - 7.5" wheel, 5.5" backspacing. (2" from hub to outside of wheel.)
New - 9" wheel, 4.75" backspacing. (4.25" from hub to outside of wheel.) <--- this yields 2.25" more than stock, sticking out from the fender.
New wheel width (minus) Old wheel width.
Old wheel BS (minus) New wheel BS
Add those numbers
That help? Offset is a whole other ballgame.
Add those numbers
Yeah, I think that is what is so confusing...Offset, Backspacing...my head spinning...
I called a guy at TireRack.com and that just confused me even more. It makes sense now... Thanks!
Originally Posted by jasonkola
you do not split the 1.5 in half. the backspacing is the distance from the mounting surface back of the wheel. so you add the whole 1.5 to the outside of the rim. plus you have to add the difference between the backspacing which is .75" which adds up to 2.25" further out than stock. if you do not beliefe me you can go and ask in the after market wheels and tires forum and you will get the same answer. there is a few experts in there who know more than me on wheels who can confirm my answer.
My head hurts...
