Anyone Run 86 Octane?
Old Mar 9, 2008 | 05:20 PM
RandomJesus's Avatar
That's what I'm thinking... I tried it to see what the truck would do.
I like performing "experiments" on my truck. So far it hasn't died -- yet.
That is one of the DUMBEST things I've read on any vehicle related forum EVER! Let us know how all that works out for ya.....yikes...
Old Mar 9, 2008 | 05:40 PM
RoushF150's Avatar
Does anyone ever run 86 octane?
I got a tank full of it last night for cheap, and so far so good.
Never tried it in this truck... but I always put it in our Compass and it has no ill effects yet.
We've been running 85 octane out here for years with no ill affects. At this altitude (>5000' DA) you won't notice any issues because the truck's already wheezing as it is.
You'll be fine as long as you don't buy 85, 85.5, or 86 octane fuel and then head down to sea level on the same tank.
Old Mar 9, 2008 | 11:12 PM
Well, I ran through that tank of 86... no difference in power, fuel consumption... or anything.
I filled it happily up with 87 and all was good.
I dunno... pointless thread.
Old Mar 9, 2008 | 11:56 PM
Bartak1's Avatar
Im not sure what your altitude is, but if its higher then it is perfectley fine to run 86 octane usually.
The higher the octane number the more resistant to detonation the gas is-thats all the octane rating on gasoline means. At a higher altitude your packing less oxygen into the cylinders compared to at a lower altitude, so detonation or preignition is harder to come by due to lower pressure inside the combustion chamber.
If his altitude is high enough (which if they are selling 86 at gas stations around there, it probably is) then there is no problem with trying 86 octane. If he did experience pinging then he would definatley want to use a higher octane gas then. But, if he didnt get any detonation, then what is everyone fussing about?
Old Mar 10, 2008 | 12:20 AM
Very true.
I know if you go somewhat south of me, there are some pretty high areas... so I'd assume that is what this is for. Never really need to go over there though.
But like I said, I popped through that tank and not one sly of a different action on the engine. All was good.
I just wanted to see what would happen... nothing happened... so... there's nothing to really discuss.
