Does the transmission fluid need to ever be changed
So I keep running across stuff on here that says the 2004+ trucks have a "lifetime" transmission fluid or something. But just last week I went in to the dealership with 47,000 miles on my truck and asked what services I need/recommend to have done. I was told one of these was the transmission flushed. So I had it done. I do a little offroading in the sand dunes in the summer, and short city trips every day.
So anyways, should I be going back into this dealer and asking why they had me pay for a service that I don't even need until 150,000 miles. This dealership service guy is also saying I should get my T-case and rear differential done. I don't totally disagree because I do some high temp offroading, but I want to make sure they are not jacking me around anymore than they may already have.
Thanks for the help/info guys
If you...
.....tow or haul anything heavy
.....do alot of traffic driving
.....drive in hot climates
.....etc
.....then I'd have it done every 30,000 miles.
I think originally it was called lifetime fluid then it changed. Dealers up here are saying every 50,000km which is just over 30,000M. I started towing last year and so I finally realized I should replace and had it flushed with Royal Purple ATF. I had @ 200,000K/125,000M at that point. I bought a 20 quart jug, so they could then also chg the transfer case.
I'm going to buy another one in spring and do it again before camping/towng starts and this time change the trans filter too.
Another good option is Amsoil ATF.
I would personally have it done every 30-40k miles regardless of driving conditions. It doesn't hurt to play it safe. I've heard too many horror stories of changing flushing a transmission with high miles.....could be a myth but I'm not wanting to find out first hand.
As far as the transfer case goes, I probably won't change that for a long time if ever. I don't use the 4wd much and I have never changed fluid in a transfer case in any truck that I've owned. Never had a problem yet but that could just be luck
wait wait some one correct me but dont the transfer cases use the tranny's fluid as in share it? i have a 97 4x4 maybe mine is diff.
if they do use seperate how do i change the tcase is it a drain plug.
wow i feel dumb asking these questions but i never heard the tcase and tranny used seperate fluids
Not sure about tcase on these, but on any tcase I've had it was just a simple drain plug/fill plug.
Originally Posted by etrevino103186
Isn't the transfer case always used?
