How to remove front driveshaft?
Does anyone on here have expierience remvoing the front driveshaft on a 04 NBS F150?(4x4) My new dust boot came in and I was planning on installing it this weekend. Does anyone have any diagrams or how to's to help me when I tackle this. The main concern is getting the front driveshaft dropped so I can slip it out of the joint. Also does anyone know the torque specs to tighten back the bolts at the U-Joint? I did a few searches but yielded nothing.
Thanks,
jrbhc8
Thanks,
jrbhc8
Originally Posted by Josiah
I can't remember the torque specs, I want to say 60ft/lbs but don't quote me. Just make sure you don't put the front shaft in backwards or you'll get a horrible bind/vibration.
jrbhc8
Special Tool(s) Installer/Remover, C-Frame and Screw
205-086 (T74P-4635-C)
Material Item Specification
Teflon® Lubricant
D2AZ-19590-A ESB-M1C111-A
Removal and Installation
CAUTION: All driveshafts are balanced. If undercoating the vehicle, protect the driveshaft and universal joints to prevent overspray of any undercoating material.
With the vehicle in NEUTRAL, position on a hoist. For additional information, refer to Section 100-00 .
Remove the front driveshaft shield.
Index-mark the rear driveshaft flange and the transfer case flange.
Index-mark the front axle pinion flange and the front driveshaft flange.
Remove the four front sway support nuts and lower the rear of the sway bar.
Remove the parts in the order indicated in the following illustration and table.
Item Part Number Description
1 N800594-S100 Rear driveshaft flange bolts
Removal Note
Installation Note
2 N800594-S100 Front driveshaft flange bolts
Removal Note
Installation Note
3 — Universal joint snap rings (part of 4635)
Installation Note
4 4635 Universal joint spider
Removal Note
Installation Note
5 4866 Universal joint flange
6 4K227 Large boot clamp
Removal Note
Installation Note
7 4421 Slip yoke boot
Installation Note
8 4K227 Small boot clamp
Removal Note
Installation Note
9 4841 Driveshaft slip yoke
10 4602 Driveshaft
To install, reverse the removal procedure.
Items 1 and 2: Driveshaft Flange Bolts Removal Note
NOTE: Do not let the driveshaft fall when the flange bolts are removed. Support the front driveshaft to prevent damage to the shaft.
Discard the bolts after removal.
Item 4: Universal Joint Spider Removal Note
NOTE: If the components are not marked and are installed incorrectly, driveline imbalance can occur.
Index-mark the driveshaft components.
Remove and discard all four snap rings.
Position the driveshaft in the special tool. Using the special tool, press out the bearing cup.
If necessary, use a pair of pliers to remove the bearing cup if it cannot be pressed all the way out.
Rotate the driveshaft and press on the spider to remove the remaining bearing cup.
Items 6 and 8: Large and Small Boot Clamp Removal Note
Using diagonal cutting pliers, cut and discard the large and small boot clamps.
Item 7: Slip Yoke Boot Installation Note
NOTE: Inspect the lubricant on the driveshaft splines and in the driveshaft slip-yoke for contamination. If contaminated, inspect the driveshaft splines and the driveshaft slip-yoke for wear. Install new components as necessary.
Slide the small end of the slip-yoke boot on the driveshaft stub shaft as far as it will travel.
Items 6 and 8: Large and Small Boot Clamp Installation Note
Using the special tool, crimp the large and small boot clamps.
Item 4: Universal Joint Spider Installation Note
Install a new spider and bearing cups.
Start a new bearing cup in the driveshaft yoke.
Check the needle bearings for correct positioning.
Position the new spider in the driveshaft yoke.
Position the driveshaft yoke in the special tool.
Press the bearing cup to just below the snap ring groove.
Repeat to install the new bearing cup on the opposite side of the driveshaft yoke.
Item 3: Universal Joint Snap Ring Installation Note
Use the yellow snap rings supplied in the kit to install the universal joint. If difficulty is encountered with the yellow snap rings, install the black snap rings, as required.
Item 2: Front Driveshaft Flange Bolt Installation Note
CAUTION: The driveshaft front flange fits tightly on the front pinion flange pilot. To make sure that the driveshaft front flange fits squarely on the front axle pinion flange, tighten the bolts evenly in a cross pattern as shown.
NOTE: Install new flange bolts.
Install the new front flange bolts.
Item 1: Rear Driveshaft Flange Bolt Installation Note
Install the new rear flange bolts.
Teflon® Lubricant
Removal Note
Installation Note
Removal Note
Installation Note
Installation Note
Removal Note
Installation Note
Removal Note
Installation Note
Installation Note
Removal Note
Installation Note
10 4602 Driveshaft
Torque Specifications Description Nm lb-ft
Rear driveshaft center bearing bracket-to-body bolts 48 35
Driveshaft-to-rear axle pinion flange bolts 103 76
Front driveshaft flange-to-front axle flange bolts 103 76
Front driveshaft flange-to-transfer case flange bolts 103 76
Shock absorber-to- rear axle bracket 90 66
Rear axle filler plug 34 25
Rear axle ring gear bolt 105 77
Rear axle differential pinion shaft lock bolt 30 22
Rear axle bearing cap bolt 105 77
Rear differential housing cover bolt 32 24
Rear tow link pinch bolt 80 59
Front axle to frame bolt 115 85
Front axle ring gear bolt 109 80
Front differential bearing cap bolt 61 45
Brake caliper guide pin bolt 33 24
Front tie-rod nut 150 111
Upper ball joint nut 150 111
Front axle wheel hub retainer nut 27 20
Integrated wheel end disconnect bolt 15 11
Front halfshaft flange-to-front axle shaft flange 82 60
First number is NM, Second number is LB-FT
Originally Posted by jrbhc8
Thanks for all the info. Can you maybe email me the images?
jrbhc8
jrbhc8
Originally Posted by Ayresusn
You just need a 12 point socket, somewhere around a 12 mm. I not sure of the size it has been over 2 years since i did my lift.
