ABS light came on???
Old Mar 2, 2008 | 12:23 AM
TonkaTruck33's Avatar
today i was driving on the highway and the light suddenly came on.. the brakes are working fine, and since ive owned the truck ive never had any problems with the brakes (or anything esle) why would the light come on?? how can i fix this problem?
Old Mar 2, 2008 | 12:30 AM
rsbeachbum2's Avatar
Happened to me a couple months ago too. Driving to and back from Ft. Lauderdale. I asked when I came back and didn't find anything either. Patshea said it happened to him too. Haven't seen it since.
Old Mar 2, 2008 | 12:35 AM
yea it turned off when i stoped to put gas. then 5min later on the road it came on again.
Old Mar 2, 2008 | 01:43 AM
Did you think about checking your brake fluid?
If not, then it might be a ABS Tone Ring on one of the axles.
Old Mar 2, 2008 | 01:45 AM
ill check my brake fluid in a bit. wat is a tone ring? where are they? are they expensive to replace? I dont think its an axle.
Old Mar 2, 2008 | 01:52 AM
A tone ring is something like this... it's not a F150's... but rather a Bronco's... but you can get the general idea... it looks like a gear, if you know what I mean...
Old Mar 2, 2008 | 02:02 AM
oooh ok, damn now to figure out wat side it is..
if i get new rotors will they come with new tone rings? slotted & crossed drilled perhaps?
Old Mar 2, 2008 | 02:07 AM
Well... it's sometimes hard to tell what's wrong... it could either be a bad sensor or else the tone ring is chipped, dented, or cracked. The cracked ones are sometimes a PITA, because it's hard to tell which one it is if it has a hairline fracture.
Anything ABS is sometimes a mystical magical thing... at least from my experiences... unless I can actually see what's wrong.
Most of the time its one of those three; (1) Low brake fluid, (2) Dented, Chipped, Cracked tone ring, or (3) Sensor failure...
Sometimes the hardest thing to do is fine which side of the truck it is on. It's a 25% chance on one of the four corners of the truck.
No, tone rings are separate.
Hope this helps... I'm tired, and I'm off to bed.
Old Mar 2, 2008 | 07:24 AM
styxnpicks's Avatar
mine went off when I tried to run two different sized tires front and back
Old Mar 2, 2008 | 08:58 AM
Ftruck05's Avatar
Could be the fluid level or maybe one of the wheel speed sensors went bad.
Old Mar 2, 2008 | 11:24 AM
splogan's Avatar
My ABS light came on intermittently so I mentioned it to the dealership when the truck was in for something else. They replaced my ABS cluster rather than screw with it.
