Built new Gauge pod
Built new Gauge pod
Well I have had my prototype in my truck for about a year so I figured I would just add my 2 new gauges to it for now. Well I couldnt use my angle rings because it was to small, so I just installed them anyway without the rings. Well I installed it in my truck and I couldnt see the gauges that well unless I leaned over onto the arm rest. So decided to build it a 1/2" wider to accomodate the rings but found that the 1/4" MDF was too thick for a proper angle. I then went out and bought a piece of scrap aluminum from the steel shop and made a gauge panel that will screw into the gauge pod. It is all wood with wood filler, primed + sanded(several times) then just shot it with gloss black(which I still found some imperfections). I like the end result and I can see the gauges clearly now.
Old gauge pod with all gauges installed
New gauge pod with angle rings and gauges installed
gauge panel with angle rings
Drivers view. Yes I know the trim panel isnt all the way snapped in that is because I still need to wire in the lights for the gauges.
Looks really slick man. Did you have to put a hole in the top of your dash to get the wires down?
Originally Posted by ONE04FX4
good work. where is your hood.
https://www.f150online.com/forums/sh...d.php?t=312985
Short story injector failed and detonated #4, hopefully truck will be done this week just waiting on head studs from ARP
Thanks for all the compliments!
