Skyjacker/Autospring 1.5" AAL Install ?
Old Feb 29, 2008 | 08:34 PM
Copenhagen848's Avatar
Question Skyjacker/Autospring 1.5" AAL Install ?
I'm assuming both of these kits have the same type of install (short AAL style) where you don't need to tear apart the stock leaf pack correct? Just making sure...
http://www.autoanything.com/suspensi...0A1891994.aspx
http://cgi.ebay.com/ebaymotors/1-1-2...QQcmdZViewItem
Are there any other 1.5 - 2" short style AAL kits out there that don't require tearing apart the leaf packs? Thanks.
Old Feb 29, 2008 | 09:56 PM
labman1014's Avatar
depends on what you call "tear apart" the leaf pack. you do have to lower the axle and remove the 2 bolts and if i remember right, it would go second from the bottom then replace everything and you are good to go....
Old Feb 29, 2008 | 10:05 PM
By tearing apart I mean bending the clamps that hold the stock leaf springs together, then bending them back to close them.
By what you described - that is not necessary, thanks
