how do I remove the center dash panel
can someone please tell me how to remove the panel on top of the dash that the Ipod plud is attached to. I need to drill a hole in it and need to see whats under it...and pdf files would be great too.
Dave
Dave
Open your ash tray and pull straight out on the lower 2 corners of the stereo and AC surround. This will pop off and with a bit of force and then you will need to unplug the wire that is at the top for the airbag light. From there, you will see 2 bolts that are on the front of the tray you want to remove. Remove the bolts and lift the tray out. Shouldn't take but a minute!
