Manual transfer case, sloppy shifter?
Anybody else with the manual transfer case able to clear this up for me. I have an 07 and I've noticed the transfer case stick has a few inches of play in it, I was curious if others have the same and its normal. I took it to the dealer thinking it was an issue and they said its normal.
Wanted to see what others manual 4x shifters are like, will probably hit a dealership to check out other manual transfer case trucks to compare.
Also anybody know if its a linkage or cable shifter?
I take it you've never driven a standard shift vehicle too?
Aslong as its normal I'm not worried though
Thats about all I've driven, which is why I thought this xfer case shifter had excessive play. Even some of the old POS cars I've had in the past didn't have the play in the tranny shifter that this xfer case shifter has.
It's normal for it to have a little bit more play than a usual truck standard shift.
A car is usually cable controlled, (unless it is a RWD car), so you don't get any vibration or minimal vibration in the stick... on a RWD vehicle, since it is a direct link to the tranny, it will vibrate and move a little bit as the chassis goes over the terrain. Again, completely normal.
Hmm...my '06 transfer case lever (goes straight into the transfer case, no cables) has very little play, or slop. Moves front to back, engages positively, and has no side to side play. 39k miles.
Sucks to hear its a direct connect to the xfer case though...will have to see how a body lift works with that setup.
well poop, now I'm really gonna have to go check another truck out on the lot and see what the shifter is like.
Main reason I'm concerned is I'm putting my lift on next month and trying to get any nagging warranty issues outta the way before I do, just to be on the safe side.
My 2006 is firm, and controlled with no noticeable play. Shifts are clean, and engagement is positive at road speeds up to 40mph or so (never needed to engage going faster than that).
