High Pitched noise cold weather
Old Feb 11, 2008 | 02:51 PM
MG94's Avatar
Greetings,
Anybody ever find out what is causing the intermittent high pitched whine coming from the engine during very cold weather ? I know it is not the belts and I have heard some mention of the MAF sensor. The engine is up to temp, but while driving in the very cold the noise shows up.
I have an 05 SCAB with the 5.4 engine
Thanks,
Old Feb 11, 2008 | 02:57 PM
pats04xlt's Avatar
Originally Posted by MG94
Greetings,
Thanks,
I really think its the alternator doing it,mine was real noisy this morning since it was 10f out in jersey.
Old Feb 11, 2008 | 03:47 PM
wadespencer99's Avatar
Power steering perhaps?
Old Feb 11, 2008 | 04:16 PM
bdholsin's Avatar
I agree with pats04xlt, I seriously think it is the alternator. Mine did the same thing this morning (-5 F) and does it every cold morning (anything below 15 F). It only lasts for about 4 or 5 seconds but I'm convinced (gut instinct) that it is the alternator. I feel that if it was the powersteering it would last longer. Also, there isn't any load on the P/S at startup (unless it is priming the system). The alternator tries to kick on as soon as the engine catches.
Just my two cents...please, I don't need change.
Old Feb 11, 2008 | 04:19 PM
bdholsin's Avatar
Just to clarify...It sounds like a really loud kazoo, right?
Old Feb 11, 2008 | 06:25 PM
JD790's Avatar
Mine does it also for about 3-5 seconds only when really cold then goes away. Probably normal?? If it was the alternator or whatever other component, replacing it probably isn't going to make the noise go away in cold weather start ups.
Old Feb 11, 2008 | 06:51 PM
YKX's Avatar
YKX
noise
It is the altenator. We just had a cold snap of -45ish cel. for the past month Changed the alt., gone now. No noise. Faulty ford mexican part.
YKX
Old Feb 13, 2008 | 02:26 PM
MG94's Avatar
Thanks for the info, the issue is going to convince FORD to change out the alternator since the problem is intermittent. I can see the invoice now with unable to duplicate.....................
