Exhaust Swap?
Exhaust Swap?
I have an 05 Scab with a maggie SIDO rear exit. My wife has an 08 screw that is stock. Would i be able to switch the exhausts (cat-back)? I know you need to specifiy the cab config when you order from maggie, but was wondering the actual differences, if any. Thanks
If your Scab has a 6.5 ft bed and the Screw has a 5.5 ft bed, then yes this system will fit both if you have this one on their website:
http://www.magnaflow.com/02product/s...=Trucks&id=957
Actually, if you look at the following link there are only 2 split rear dual set ups offered from Magnaflow: 16614 and 16615. The 16614 is for 04-08 Screws or Scabs in the 5.5 ft or 6.5 ft bed, respectively (most likely what you have, >99% sure). And the 16615 is for the sport models with short beds.
http://www.magnaflow.com/02product/s...44&cat=F%2D150
Originally Posted by MOford21
marwilli, how loud is that maggie si/do?
I've been wanting to get a si/do, just wondering how loud they are.. because i want something that you can hear all the way through the rpm range.
