4" lift prices
Old Feb 10, 2008 | 03:48 PM
brocious03's Avatar
4" lift prices
just wondering what is a good price for a quality 4 incher installed. I have a 2.5 as and I am going to tuck some 35s under the rig since they will hopefully fit with no problems and then just get the lift later on and use the same rims and tires. I think that the 35s really look nice with the 4 inch lift not too big and not too small. Any advice or info on my idea is well appreciated. Also I was wondering if I should/shouldn't take off the a.s. when I do get a lift (for those of you who have had both)
Thanks Brian
Old Feb 10, 2008 | 03:52 PM
Copenhagen848's Avatar
You're probably looking at around $2300-$2500 installed with shocks.
If you leave your leveling spacers on, the front will sit 2.5" higher than the rear once the suspension lift is installed. You'd need bigger blocks or an add-a-leaf in the rear to level it out again.
I personally would take the spacers off.
Old Feb 10, 2008 | 04:07 PM
brocious03's Avatar
thanks for the response. thats what i was thinking as well.
GO GREEN!
