Fog Lights Quit Working
Anyone have any ideas why my fogs would quit together? I checked the fuse in the passenger side kick panel as well as the relay under the hood. Did I miss anything? I was wondering if one bulb burns out will both not illuminate...hmmm.
'06 F-150, 5.4L.
Ideas???
'06 F-150, 5.4L.
Ideas???
I just had a bulb changed on mine the other day, the guys at the dealership said they have been seeing alot of them come in with the sockets corrored. If you live in an area where they use alot of salt and sand on the roads that might be your problem.
I know when I was my truck it is always full of sand and stuff even in the summer.
It was the darndest thing...BOTH bulbs were out. As near as I can tell they went at almost the same time. I drive with them on at night and would definately be able to tell if one was out before the other.
Picked up two from the dealer (jeez, they don't give these things away) and installed 'em. All is good.
both of mine went out at the same time also,when I took out the old bulbs I noticed that there was some corrosion on the harnesses.put a little dielectric grease in there and new bulbs and all is good now.
