flair sides ?
flair sides ?
there arent many flair side's here in tennessee, lots of farms and the farmers like long bed trucks. post some flair side pics, this is my first ever flair side. I'd like to have some idea's for mods on a flair side....thanks guys/ gals
stupid question !!!
since our beds are fiberglass, i think i'm correct on this.. if i run my exhaust out in front of the back wheels right below the step, will the heat/ exhaust effect the ( bed/step ) in any derogitory way? i'm considering dual tips in front of each back tire. any and all comments appreciated on this consideration. thanks, scott
Are you going to be towing alot or at all with the truck? If so, then I would run the exhaust out behind each rear tire or out behind the pass. tire, just to get the exhaust to exit as far away from the cab as possible. I have been in a couple of trucks with the exhaust infront of the rear tire and it gets really annoying while towing for any distance. Plus if you go out the sides then you don't have the exhaust bouncing off the trailer that you are pulling.
Nightranger, going along with what PHS79 said, try to avoid a dual out the back if you plan on a lot of towing. A few have reported that the pipes set their spare on fire under extended towing, specifically the magnaflow setup. I would imagine that all dual rear exits under the bumper could cause this problem if given the right conditions.
Here is the thread i was thinking of https://www.f150online.com/forums/sh...+truck+on+fire
and another one https://www.f150online.com/forums/sh...+truck+on+fire
i looked at your albumns, very nice camper, btw. it doesnt say anywhere in your albumn ( are you lifted )?
