Turning front axles
Turning front axles
Today i was at a light and another lifted f1 turned in front of me and as he turned his front axles cough my eye they were turning. Our axles dont turn with the front wheels when in 2wd right, that would mean he was driving in downtown tempe in 4wd???
Josiah I am not saying you are wrong but can you describe how the vacuum holes work. How does it disconnect the axle from the hubs.
yeah it's a fail safe feature so you're not SOL if your solenoid fails while offroad. By default your hubs are locked. There is a sleeve with internal gear teeth that locks into place for 4wd and slides back when vacuum is present (which happens at the turn of the key), if there is a leak or the solenoid fails the vacuum is not present and that sleeve locks. Sometimes my hub would fail and I thought I'd need a new hub until I pulled it apart and reseated the sleeve. This is a good feature for gas mileage reasons but at the same time just adds to the likelihood of something going wrong.
thats what I though so this guy was just driving around town with his hubs messed up. haha (wheres that simpsons guy when you need him)
Doubtful but always a posibility.
yes I have had numerous problems with the integrated wheel hub . I have now replaced 4. if you only get partial vacuum then you drive down the road with the hubs partially engaged and wear down the teeth. problem is you never know it till you need it.
also acording to ford it saves .5 gallons a mile not rotating the axles.. i believe chevy and dodge rotate the axles all the time.
