Boost Gauge & Trans Temp Install Diagram???
Old Jan 19, 2008 | 09:47 PM
bl@wnFX2's Avatar
Exclamation Boost Gauge & Trans Temp Install Diagram???
Anybody know where good boost gauge diagrams/directions/instructions are for a new body style F-150 is located??? Also needed for trans. temp. gauge with thread-in style temp. sending unit???
ANY & ALL INFO IS GREATLY APPRECIATED!!!
Old Jan 19, 2008 | 10:50 PM
bl@wnFX2's Avatar
Exclamation
Anybody???
Old Jan 20, 2008 | 09:24 AM
ONE04FX4's Avatar
Talking
on the trans temp gauge you need to make sure you have the short sender. if you have the long sender it will hit inside the transmission. the place to put the tranny sensor is on the drivers side near the front in the middle. you will see a little 8th inch plug. which type huffer do you have.
Old Apr 16, 2008 | 07:52 PM
chains350's Avatar
Is this valid for the transmission used in the 5.4L? When you state short or long, what is too long? Thanks!
