Glad I'm running Mobil-1 Synthetic!
I have had my oil changed every 3000 miles at the dealer. It always had the ticking noise at start up and was loud at idle. I noticed recently that the truck doesn't do this anymore. No more knocking on start up and has seemed to got quieter during idle. I have not changed anything....still getting oil changed at the dealer. I have just over 50 000 miles on it and it is an 04.......5.4l...maybe it is getting broke in and everything is loosening up ....also I have never had any problems with it other than brakes
Originally Posted by cndcowboy
I start my truck up in -40 with dino oil, always fires right up, no problems, no grinding sounds.
I call BS on this one. -40 deg C or F? Maybe if you have the thinnest possible dino made and its plugged in... perhaps, but even then there is no way your oil pressure neddle is swinging over as quick as it would with a 0/20 synthetic...
synthetic doesn't break down like convintional oil and I change my oil every 6k or 6 mths which ever comes 1st which is always the 6 mths cause I don't drive that many miles I have a 2005 w/ 19k miles on it I buy the cases of mobil 1 oil at Costco for $29 and a filter runs me another $5 so it runs me $70 bucks a year for oil changes
Originally Posted by scott1981
For $40.19 I change my oil every 3000 miles using Mobil 1 5w20 and the motorcraft filter.
Is this overkill? Maybe.
Do I care? No
Why? Because I feel that I should keep my truck in the best shape possible. Why not spend a little more money and know that my truck is protected by better oil. I think its worth a few more dollars to save me $$$$ in the long run.
Also, just remember, while the oil my be able to go over 10000+ miles...that doesnt mean that the oil filter should.
Do I care? No
I call BS on this one. -40 deg C or F? Maybe if you have the thinnest possible dino made and its plugged in... perhaps, but even then there is no way your oil pressure neddle is swinging over as quick as it would with a 0/20 synthetic...At -40 I do plug in the block heater. I don't care what oil you use, they get hard to start at those temps. Batteries don't seem to like those temps.
hmm glad for your truck and all. i run my truck on just reg 10w30 and shes got 168,000 miles sat outside lastnight in -10 degree weather started her up this mornin when it was -2 outside.. started RIGHT up not a weird sound nothing. Just a normal start up. thats ford for ya. Shes a tough truck
Originally Posted by bone79
i've been running mobil-1 in everything i've ever owned, no problems so far.
I run synthetic oil and ford filters, and I go overkill on the oil changes for a synthetic oil. I'm really considering going to Royal Purple for all my fluids, I haven't tried them yet, but I hear good things.
Yeah nothing likes -40, I'll second your BS. You probly couldn't even poor dino oil out of the can after its sat at -40 overnight, nevermind your engine make oil pressure with it right after start up.
I hope that C or F question was a joke seeing as how it is the exact same temperature.
I'm not saying mine wouldn't start @ -40, it would 99% of the time, (especailly when my original battery died and I put in a real battery) but it wouldn't sound good at all. And might be a 1.5 second delay b4 oil guage wakes up... My biggest complaint is around teh whinning the Ford power steering pump makes... I finally flushed it and put in Royal Purple max-ex steering fliuid... Helped big time.
