Glad I'm running Mobil-1 Synthetic!
Old Jan 3, 2008 | 02:10 PM
scott1981's Avatar
Synthetic oil is a better oil, plain and simple. I know people over 60 that eat fattening foods and never workout, but I would by no means reccomend that lifestyle to others. Just because it works doesnt mean it is the best option
Old Jan 3, 2008 | 02:27 PM
StoneF150's Avatar
Originally Posted by cndcowboy
I'll pass thanks, the extra expense isn't worth it. FYI I had a jetta with over 200,000 miles on it, all it ever had was dino oil, not even the blended stuff. Never had engine troubles with it. When I sold it the people wanted a compression test done on it and it checked out just fine.
There isn't really an extra expense because on synthetic oil you can go twice as long which means you will change your oil 2 times to 1 synthetic oil change.
Old Jan 3, 2008 | 02:29 PM
Except the longer you run any oil the greater the amount of oil breakdown, so are you really saving or exposing your engine to unnecessary wear?
Old Jan 3, 2008 | 02:30 PM
dkstone05's Avatar
that's a good one.
Yes synthetic is better but at the same time for a lot of people it is overkill and not worth the extra $. Don't think anyone is arguing that point.
Old Jan 3, 2008 | 02:31 PM
scott1981's Avatar
This is true, the Motorcraft blend everyone suggested 3k and that was about a $34 oil change. Synthetic the mechanic told me go 5k and I paid $54 so Its a bit cheaper, plus I dont have to get my oil changed as often. So I save money, save time & have a better oil
Old Jan 3, 2008 | 02:32 PM
dkstone05's Avatar
For one before trying to go twice as long you should have the oil tested to see how it is holding up. Also I've noticed a lot of people on here that run synthetic but still change at 3k miles which in most case overkill. Also make sure you put in a high end filter such as K&N for the extended OCI.
Old Jan 3, 2008 | 02:44 PM
dkstone05's Avatar
For me the money wouldn't make since. I change my own oil using a M-craft for about $21-$22. For M1 it would run me about $41. So either way it is about the same price if I went 6k miles between changes.
scott1981's Avatar
http://www.mobiloil.com/USA-English/...orld_Home.aspx
That really goes to show how well synthetic can protect your engine, even in the harsh enviorments shown,
Old Jan 3, 2008 | 02:45 PM
scott1981's Avatar
True but you get more time to relax instead of screwing with the truck
Old Jan 3, 2008 | 02:57 PM
dkstone05's Avatar
Hell my brother has been know to go 20k miles on the cheapest oil he can find and his Yukon still runs good, but I wouldn't recommend it. I think half the price of mobil 1 is due to the advertising they do.
Old Jan 3, 2008 | 03:00 PM
dkstone05's Avatar
But it gives me a exuse to give the wife why I need to spend time in the garage drink beer. Also I don't mind changing the oil it gives me a chance to check things out, I usually never look at the mechanical side of the truck unless I'm changing oil.
Old Jan 3, 2008 | 03:08 PM
scott1981's Avatar
Hard to argue with that
cndcowboy's Avatar
I do 10,000 km (6250 mile) oil changes with the ford oil on my truck. I end up changing the oil about every 4-6 weeks in the summer time.
Old Jan 3, 2008 | 03:27 PM
scott1981's Avatar
IzInBloOm's Avatar
The trucks are built and tested to start at -40deg with the factory rec'd oil.
Motorcraft 5w-20 Non-synthetic.
-ii
