04 leveling kit
Old Dec 29, 2007 | 10:19 AM
ford 5.0's Avatar
04 leveling kit
Hi all.. New here i want to level my 04 4X2 Supercab 4.6 what size should i get to level my truck. pic will be up soon..... TKS Mike
Old Dec 29, 2007 | 10:31 AM
PHS79's Avatar
How do you want to level it? By taking the front end up or lowering the rear?
If you want to raise the front, get a 2" Autospring levling kit. If you want to lower the rear then I would look at some groundforce drop shackles.
Old Dec 29, 2007 | 10:38 AM
ford 5.0's Avatar
i want to level the front with the rear
Old Dec 29, 2007 | 10:41 AM
sylentbutvylent's Avatar
2" Auto Spring leveling kit via Ebay......Install is pretty easy but you will definatly need a alignment after the install...
ford 5.0's Avatar
will a Daystar 2 1/2 Inch work. i can get a free one from my brother or is that to high
Old Dec 29, 2007 | 10:53 AM
PHS79's Avatar
You will sit nose high with a 2.5" kit. Then you would need something to raise the rear, add-a-leaf, airbags, or a block.
Honestly I would just buy the Autospring kit, it is only $90. If you put in the free Daystar you might endup spending alot more more than the $90 trying to raise the rear so you are level.
Old Dec 29, 2007 | 11:03 AM
ford 5.0's Avatar
ok... thanks for the help
