Tires and mud flaps?
Do you guys know if 35s will fit if you have the husky mud flaps? I really like havin the mud flaps so i don't want to lose them. But at the same time i really want 35s, so just wanderin if they will fit. And if anyone has pics of this please post them. thankz JOSH
there was a guy with a blue and tan lariat of 35 muds on his lariat, i cant remember his name. i think he was from alaska. i think most people take them of because they rub though. thats why i wont run 35's, flaps are a must up here.
i have 33s a 2in as and husky flaps and there is plenty of clearance with both the stock wheels and my aftermarkets that are 17x8.5 with 5in of backspacing. i dont think i have enough room for 35s though.
Originally Posted by KSpencer
Mmmm. I just put a set of 285/65R18's on my stock FX4 rims today at the dealership. These are not quite a 33 inch (about 32.8 inches), but they barely rub the Huskys on the inside edge of the flap with the outside edge of the tire when turning. I am going to get pics tomorrow of the rubbing and see about trimming to fit. I have the 2 inch AS too, so I am not sure why your set up is not rubbing. I think that the stock rims have 5.5 inches of backspacing, so yours would stick out a little further. What is the width of the tire, maybe this is the difference? Just curious.
What is the width of a 305 tire in inches????
Section Width: 12.00 in / 305 mm
Rim Diameter: 18 in / 457.2 mm
Overall Diameter: 33.61 in / 853.69 mm
Sidewall Height: 7.80 in / 198.12 mm
Radius: 16.80 in / 426.72 mm
Circumference: 105.5 in / 2679.7 mm
You guys are talking about these, right?
http://www.autoanything.com/mud-flap...0A2547405.aspx
I did not get out today to do much, but will have pics soon.
Edit: I also have the factory flares, but I'm not sure if that would make much difference.
Yeah those are the flaps that i have.
Stock: Goodyear Wrangler AT/S 275/65R18C
Width: 10.8 inches
Diameter: 32.1 inches
Circumference: 100.7 inches
New: BFG T/A KO 285/65R18E
Width: 11.2 inches
Diameter: 32.6 inches
Circumference: 102.3 inches
* only 1.6% bigger in diameter *
