wet carpet!
Old Dec 13, 2007 | 11:13 AM
GA06KR4x4's Avatar
wet carpet!
i pulled out my husky liners yesterday and found a little bit of moisture under the front passenger side. this is about the third time i have noticed the wet spot.
nothing has been spilled there and i would like to see if its an easy do-it-yourself or something the stealership has to fix.
thanks ya'll
Old Dec 13, 2007 | 11:22 AM
beckerjs's Avatar
heater core or plugged a/c drain possible and not ruling out some door seal leak, either way if its under warrenty I'd send it back
Old Dec 13, 2007 | 04:05 PM
GA06KR4x4's Avatar
the truck already has 50k so i guess the dealer gets to figure it out. i really wanted to know if it was a common problem.
thanks for the reply
Old Dec 13, 2007 | 06:02 PM
rdalley's Avatar
I am dropping off my 06 at the dealership tomorrow for the same problem. I will let you know how it turns out.
From what I have read there is a common problem with these trucks leaking in the front passenger and the trhird brake light, which I had fixed once at the dealer and is leaking again.
Old Dec 13, 2007 | 06:23 PM
2005lariatky's Avatar
Do you have a sun roof? If so the drains may be clogged. They should be on the door pillar around the door henge. I had this problem with a Volkswagon.
Old Dec 13, 2007 | 07:24 PM
GA06KR4x4's Avatar
please let me know how it turns out.
i do have a sunroof but havent found anything to lead me to believe thats the problem. it rained today in atl and there is nothing there. i also have used the a/c and heater both latley......its just bothersome
Old Dec 13, 2007 | 08:38 PM
07screw's Avatar
my wife's 06 expedition did the same thing pulled the floor liner out and floor was wet i let it dry out and when it rained wet again
took it to the dealership they have a subcontractor that detects leaks and not to mention he only works one day a week for the ford dealer
first time they told me that it was probably condensation from the ac
I said bullsh*t they finally found a leak at the fire wall under the cowl plastic
Old Dec 14, 2007 | 02:25 AM
memLT-1's Avatar
My 06 Screw did the same thing. Dealer farmed it out and I have no leaks. Have no idea where the leak was coming from but from all I have read it was probably the AC drain.
Old Dec 14, 2007 | 08:40 AM
jrbhc8's Avatar
My dad's 06 was in for the same problem a month ago. Something with the condensation drainage. Seems to be a common problem arising.
jrbhc8
Old Dec 15, 2007 | 10:49 PM
rdalley's Avatar
OK, I heard from the dealer today. Service manager said they see a lot of them and it is usually a windshield. On mine they think it is the seal between the firewall and the A/C. They are going to order the parts and I have to take it back when they get them. I am worried because i have heard that it can be caused from about 8 different things.
Old Dec 15, 2007 | 11:50 PM
mrshadetree0222's Avatar
well, i do hope that they buy you the gas to return about 4-5 times till they find where the leak is. went through that with wifeys chuv-it-or-leav-it(cheverolet) colorado. 3 trips later they found the leak and it wound up being a plug in the floor pan up next to the firewall!
