Do I need a PosiTrak rear
Old Dec 12, 2007 | 10:10 PM
inurok's Avatar
My 2005 Screw has the non-limited slip diff. I have a roush supercharger installed. Is the non slip diff a bad combo.
Old Dec 12, 2007 | 10:29 PM
If you want to do one wheel tire burners.
Or what I call... peg legged burnouts...
Old Dec 12, 2007 | 10:31 PM
GJ Screw's Avatar
or..a one tire fire
Old Dec 12, 2007 | 10:33 PM
Originally Posted by GJ Screw
or..a one tire fire
Old Dec 12, 2007 | 10:34 PM
inurok's Avatar
or..a one tire fire
That about says it all for me right now.
Old Dec 12, 2007 | 10:36 PM
Sheesh... you could've included my post in there.. (I knew you had a chuckle when you read it... you had to... peg leg burnout... haha)...
I'm sorry... I dunno what's gotten into me.
But on a serious note... I recommend an Eaton posi.
Old Dec 12, 2007 | 10:56 PM
GJ Screw's Avatar
X2, or atleast find a junkyard that has a 3.73 ls..
Old Dec 12, 2007 | 11:27 PM
inurok's Avatar
Right now I have the 3:73 non limited slip. Where can I order limited slip and will any shop install it or just a speed shop?
Old Dec 12, 2007 | 11:40 PM
GJ Screw's Avatar
I would think that any shop should be able to do this, the stealership would be able to but would prob charge you out the rear.. Try a local garage, just make sure that they have experiance in this type of service. From what i hear it is very specific and easy to screw up.
Jon
Old Dec 12, 2007 | 11:41 PM
extremeethan's Avatar
Lately I have been only doing one wheel peels, how can I tell for sure if my LS has gone out. Its been raining a bunch (in AZ i know the last 2 weeks doubled what we've had for the year) and I like messing around and it will only peel one wheel around corners when I want to spin both and kick the rear around. I have RP in the diff, could it have to much ls additive? My LS just doesnt seem to be hooking up like it used to, it used to be scary driving in rain it would break both loose all the time and slide the rear around, and just punching it I think only one is breaking loose.
Old Dec 12, 2007 | 11:50 PM
Sounds like the clutch pack is bad in the LS. I suggest getting a better LS, like an Eaton.
As far as a place to buy one, look on the internet.
I like these people: http://www.drivetrain.com/eatonposi.html
Old Dec 13, 2007 | 12:22 AM
ParkM's Avatar
www.ring-pinion.com
Old Dec 14, 2007 | 05:20 AM
RoushF150's Avatar
The only time it's a problem is when you lose traction. Since you're running a Supercrew, I'm sure you have troubles lighting up the tires even with the Roushcharger.
Are you able to break them loose or do you get decent traction?
