all of a sudden my compass gauge is going crazy....
Old Dec 11, 2007 | 05:36 PM
K1NGoftheRanch's Avatar
itll say sw then se then s then e then w and keeps switching back and forth all of the sudden. then a few times it said circle to calibrate and then calibration complete. it said that like 5 times. i have the edge which i have been running with no problems but jsut to ensure it wasn't that i swapped back to stock. it did the same thing so i went back to lvl 2 with my custom settings. i did have the top of my windshield tinted today tho...(just the strip) i dont know if that has anything to do with it b/c im not sure where the compass actually is located in the truck. any help would be appreciated. thanks
Old Dec 11, 2007 | 05:41 PM
you have to hold down the button to go into calibration mode, then do 3 full circles.
Mine usually freaks out when I disconnect power to the body, the power that is always supposed to be connected.
Old Dec 11, 2007 | 05:46 PM
Ftruck05's Avatar
Patman is talking about the trip/reset button on the ododmeter I think.
Old Dec 11, 2007 | 05:47 PM
SAJEFFC's Avatar
I would bet its the window tint. The compass module is located on the back of the rearview mirow. I believe a lot of tint contains a thin metal film in it to reflect sunlight. If it just started doing it after the tint job thats probably it. Just a thought...
Old Dec 11, 2007 | 06:02 PM
well i cant reset it...as soon as i go to reset it (per instructions in my manual) it says check compass module...so idk...i guess ill have to take it to the shop??
Old Dec 11, 2007 | 06:12 PM
SAJEFFC's Avatar
Guess if it were mine I would try that first and see if it checks out. They may tell you the tint strip has to go or use another kind of tint.
Old Dec 11, 2007 | 06:19 PM
yeah after i spent 50 bucks on it....haha...never fails...
Old Dec 11, 2007 | 07:57 PM
memsu's Avatar
You just got your windows tinted correct? And they did the front windshield. I know exactly what happened because it happened to me also.
They used soapy water to help the tint stick to the windshield, and in the process of doing that some of the soapy water went into the compass housing right below the rear view mirror. The bottom will pop off and you can get to the circuit board and dry off the contacts. That's what worked for me, and I've yet to have any more issues. If the board is fried show the tint shop what happened and let them replace it.
Old Dec 11, 2007 | 08:56 PM
memsu genius....fixed...opened it up like you said and sure enough soapy water....dried it off and cleaned off the little bit of dried build up around the board (still a small amount i couldn't get it all off) recalibrated and bingo...works perfectly...thanks
Old Dec 11, 2007 | 09:02 PM
memsu's Avatar
No Problem!!
Old Dec 11, 2007 | 09:05 PM
Screw-Me-05's Avatar
50 BUCKS for a window strip.........? good god
Old Dec 11, 2007 | 09:07 PM
yeah well normally it would be cheaper but i had another window shop tint my windows a while back and now they dont tint anymore so i went to a new shop and since they didn't tint the other windows its a little more money...but whatever
Old Dec 11, 2007 | 09:18 PM
memsu's Avatar
I believe mine was $30, but I also got the front side windows tinted as well. The only reason I had them tint the strip on the windshield is that no windshields come tinted from the factory anymore. I was driving East every morning and the sun would always be in my eyes right where there should have been tint. Now I need a new windshield, but don't want to replace that because Ford might be buying my truck back after my lemon law settlement.
Old Dec 12, 2007 | 01:21 AM
No i was talking about the compass....
Also i had my truck done: 5 windows for 80 bucks.....
Old Dec 12, 2007 | 02:05 AM
Not bad... not bad at all.
I still can't get over that truck patman...
