Air bags and lift
Air bags and lift
I know someone put air bags on their lifted truck, I searched but didnt find anything. Could someone post the pics or the person that did it explain it to me? I really need to do this now that I will be towing my ranger a lot more.
I found a place that sells spacers for lifted trucks but what size do I need. My truck has the procomp kit so it is only a 2.5 inch rear lift right? Also would I need a tapered spacer or strait spacer it says to use the tapered one when you have factory tapered blocks, are our blocks tapered?
I remember someone posting that Firestone will actually make you a kit specificly for a lifted truck, this may just be an internet rumor, but worth checking into.
I actually talked to the airlift rep yesterday. He said they are now making one sku number that will work with any lifted truck. It is a spacer kit that is available now, and works as a shim kit that you can interchange to get the proper angle and spacing. Hope this helps.
I actually talked to the airlift rep yesterday. He said they are now making one sku number that will work with any lifted truck. It is a spacer kit that is available now, and works as a shim kit that you can interchange to get the proper angle and spacing. Hope this helps. I could not find the info on their website, so you may have to email them.
