Backup Sensor
Backup Sensor
I'm having an issue with the back up sensors on my 2004 screw.
When I put the truck in reverse, the sensor turns off. The button won't turn the sensors back on while in reverse.
Kind of defeats the purpose.
Anyone had this problem?
Ron
Ron
Ron
Ron
Kozwald
When you would put your truck into reverse would you get a short beep when the light would come on? This is what mine does and I check the sensors one be one, check the fuse and I even check for trouble codes... If your truck did as stated above, did the speaker fix the problem?
Rambo...
What year is your truck?
The dealer told me the speaker is part of the module and its over $100 for my 04 Lariat!
I think you should be getting a short beep from the speaker when you first put your truck into reverse, when the light first comes on. I would say your speaker may be part of your problem. Mine doe beep, and the sensors seem to be working as I check them one by one.
