Amp stuck on...dead battery
Old Nov 18, 2007 | 12:59 PM
Devin4X4's Avatar
Hey guys...my battery to my truck has died on me twice the last few days. Couldnt figure out the problem..little did i know my amp is stuck on? What should i do about this..Is it the amp? just unplug it
Old Nov 18, 2007 | 01:08 PM
K1NGoftheRanch's Avatar
it should be wired to a remote turn on off your hu and shut off when the stereo is off....if it is and it wont shut off for some reason i would def unplug it
Old Nov 18, 2007 | 01:42 PM
hllon4whls's Avatar
If you want to keep the amp, and it is wired correctly (Ie HU unit shut off), place a properly rated relay in line with the power and have the amp only have power in ACC and Run.
Old Nov 18, 2007 | 01:55 PM
I used to have an amp in my '99 along with a JL 10w7, and I had the ACC wire along with an inline switch... just in case... I always turned it off after I turned off the truck for the day.
Never had a problem with a dead battery even before putting the switch in... but I just got antsy.
But not only that... but there were lots of times when I didn't want the sub kicking... but I wanted the radio on... just flipped the switch and the amp would turn off.
Old Nov 18, 2007 | 03:59 PM
azmidget91's Avatar
double check your ground....
