Winter storage
Winter storage
Hey everyone,
I about to store my truck in a garage for the winter (about 4 to 6 months) and wondering if there is something i should do to help protect it for the cold winter here in Michigan. The only thing i can think of is put stable in the gas. any help will be appreciated.
When I had my 03 GT I stored it every winter .. this is what I did.
Put a tarp down on the concrete floor of my garage, I had done a bunch of research a read a lot about concrete floors and moisture problems. Filled the gas tank with as much fuel as I could push in then dumped in Stabil. Disconnected the negative from the battery. Jacked the car up and put it on jack stands with a lot of the weight off the tires, but not all of it. Was trying to prevent flat spots on the tires and metal fatigue in the suspension. I also treated the leather, vinyl and all rubber seals.
Then just let it sit and waited for the warmer weather.
Originally Posted by bri687
Hey everyone,
Originally Posted by TonkaTruck33
why would u wanna store a 2006 ford truck...? its a truck...
If you store your truck, what do you travel in during winter?
Or do you hibernate?
Won't see me storing my truck! I bought it to work the crap out of it! I'm actually praying that we get hit with seveal Blizzards this winter, so I can play with her, & the new BFG's 285's...............
The question was, how to store your truck in the winter, so whether you think it's a good idea or not has nothing to do with the actual question.
With the Mustang I do pretty much what Fordsforme and Tbird stated. Fuel stabilizer in full, or close to full tank of gas, park the wheels on carpet and change the oil/filter on the day it's being stored. That's it.
Oh, people will argue against doing this for various reasons, but, I also like to start it up and get it good and hot once every month or so. I make sure I let it run for a good 20 minutes to half an hour with some gentle throttle every now and again so it's not just idling. I've tried leaving it all winter without startup but found that letting it sit creates a small leak ( around rear main seal, and it's new) because seals dry up. By starting it up and letting it get hot the seals are freshened up and there are no leaks found underneath it in the spring.
Well i don't want to store my truck but i can't take it with me so this is my only option. What do you recommend to eliminate rats? and moisture?
