Bank 1 & 2 is too lean????
Old Nov 13, 2007 | 09:02 PM
99ls1z's Avatar
Check engine light came on so I went to autozone to read the code. They said bank 1 & 2 or too lean? Is this some type of sensor going out?
Old Nov 13, 2007 | 09:43 PM
Tally TransAm's Avatar
most likely a vacuum leak
Old Nov 14, 2007 | 01:58 AM
khendrix2374's Avatar
Check for any obvious hoses not hooked up. Then try cleaning the MAF sensor.
This stuff works great. remove the MAF sensor and spray it down throughly.. on the sensor part.. (The wire). Let it dry for an hour of so.. then re-install. Leave the battery unpluggd while your cleaning the MAF..
Try this and report back with results.
Old Nov 14, 2007 | 02:06 AM
i.ride.suzuki's Avatar
How many miles on the truck? Any modifications?
Old Nov 18, 2007 | 01:20 AM
Adam06FX4's Avatar
Registered User
when was the last time you changed your fuel filter?
Old Nov 18, 2007 | 08:21 AM
deapee's Avatar
probably a vacuum leak, like Tally mentioned.
