Squeaky Back Window
Old Nov 12, 2007 | 10:32 AM
Huttos F-150's Avatar
Squeaky Back Window
My back sliding widow squeaks when I am driving down the road when it is completly closed. When it is cracked just a bit it does not squeak at all. Does anybody have a suggestion on how to fix it?
Old Nov 12, 2007 | 10:34 AM
FX4REACTION1's Avatar
Take it back to the dealer there's a TSB out on it. They'll fix it free of charge.
Old Nov 12, 2007 | 11:22 AM
ryanbeal's Avatar
What are the details of the TSB mine is out of warranty so I will need to fix it myself. It only happens when it's in the 50's outside, weird.
Old Nov 12, 2007 | 11:42 AM
ranorris2's Avatar
I had the same problem and posted a thread about a week ago. Check this thread out:
https://www.f150online.com/forums/sh...d.php?t=307594
This should help you, if not then give me your email and I will email you the pdf file I received.
Old Nov 12, 2007 | 11:45 AM
supachargd2k5's Avatar
Im having the same issue, my e-mail is cbishop87@hotmail.com if you dont mind. Thanks
Old Nov 12, 2007 | 11:54 AM
ryanbeal's Avatar
ryanbeal2003@yahoo.com
Thanks bro...
Old Nov 12, 2007 | 02:51 PM
ranorris2's Avatar
I will send it to you guys tonight after I get off work...
Old Nov 12, 2007 | 09:43 PM
ranorris2's Avatar
Check your emails you should have it
Old Nov 12, 2007 | 09:52 PM
TexfordD's Avatar
Mine rattled on the '07 and there is a tsb which is covered under warrenty.
They install a felt strip top and bottom
Old Nov 13, 2007 | 09:02 AM
renaud's Avatar
I've got the same annoying noise. Please email the fix to grenaud25 at hotmail.com
Thanks!
Old Nov 13, 2007 | 09:13 AM
dkstone05's Avatar
could you send this to me as well. I have the squeak and the dealer never can reproduce problem, since it is intermittent. It's not rattling now but I know it will come back and bother the heck out of me. Thanks
nmayhorn@yahoo.com
Old Nov 13, 2007 | 10:08 AM
Please send to me as well. I am going to make a trip to the stealership.
Old Nov 13, 2007 | 10:23 AM
Irish FX4's Avatar
Glad to see my PDF file is helping so many.
When my rear window was squeaking the stealership did the TSB fix where they put a grease around the rear window to stop the plastic trim from rubbing on the paint causing the squeak. This lasted only about 6 months and the squeak came back. I talked to one of the mechanics and told him about it and he said that it was a temporary fix and that they remove and shim the rear window out about a 1/6 to 1/8 now so as the plastic trim does not rub. So i got them to do mine while it was still under warranty and i have not had a squeak yet. But it is still early days yet. They only did it about 2 months ago so only time will tell.
Old Nov 13, 2007 | 10:29 AM
Hawkz28's Avatar
Hi I have the same problem.
Can you also send me the PDF, I'd appreciate it.
bhawalka@comcast.net
Brian
Old Nov 13, 2007 | 04:56 PM
I forgot to put my email up. mhutto77@yahoo.com
