Maintenance periods
With the spark plug issue, oil change variables and personal experience, How would you modify the recommended maintenance on your truck. 3k or 5k for oil changes? When to clean/change plugs? And such the like.
Everyone has an opinion on these things. I just can't go too long between oil changes, so I change mine every 3500 to 4000, usually about 3800. The plugs, I will wait till about 85,000 or so. I am near 58,000 now. The fuel filter, I do about every 12,000 to 15,000. I have a K&N air filter that I clean every 15,000. The other stuff, I do according to the Ford recommendation. Oh, and I rotate the tires every oil change.
My oil is done every 3k with the tires rotated each time. Fuel filter is done every 15K. Tranny flush every 30K and now I am going to be changed the filter every 15K. My truck is almost two years old now so I plan on flushing the brake fluid soon as well as the antifreeze. Differential and power steering fluid service will be at 50K.
