replacement upper control arm boot?
Hey All,
Does anyone know if they have replacement upper control arm boots available? |
I had a tear in my upper ball joint and I called around asking about a replacement boot. All I got as a answer was its a solid assembly. If the tear isnt in a fold try and use inner tube glue. I used it till I could replace it. And if your gonna take it to the dealer or a mechanic to get the assembly installed, buy the part from getfordparts.com and have them install it. I believe the assembly is $70 on the web but if you go to the dealer they charged me $120.
Well that's a bummer to hear. Thanks for the advice. I'll order from them, sounds like a deal. :rocker:
Are you talking about the upper ball joint boot? That's part of the ball joint assembly... Grab a new joint and stab it in...
I can get you a good price on a stock UCA (10% over dealer cost most of the time) if you don't mind traveling into fresYES. ;)
