Lift options
Lift options
I got some scenarios for ya. Since im not going with rize. In the long run i want to run 37s. Might be a year from now or longer... I want to start out with a 6inch and move my way up.
I can get a fabtech 6inch and run 2.5autospring on top with aal
6 inchPro comp stage 1 with with bilsteins and aal
6inch pro comp with 3 inch body lift
In the long run which one should i go with? im going to start with a 6inch and run 33s til they wear out?
i would get the fabtech with DL coilovers and 35s. once the 35s wear out and you want 37s, just crank up your DLs, toss a AAL in the back and 37s will fit no problem.
Originally Posted by black07screw
tuff4rd, what are the backspacing and size on your wheels. I was looking at the RCD as well heard it was agreat kit. I wanted to keep my wheels tucked as much as possible. Do you have any rubbing. THX
BTW, no rubbing
tuff4rd
Wow, really you dont have any rubbing, even at full lock? I was wondering what you thought if when I get my RCD kit it get 20" KMC Hoss there 20x9 with 5.7" of backspacing and I want to run 35x12.50 toyo mts, how do you think that would look, thanks for your help tuff4rd
