Bed Extender and Bed Liner Question
Old Oct 22, 2007 | 08:59 PM
mc2912's Avatar
I just picked up a used (looks new!) bed extender for my Screw w/ bed liner. Found all the part numbers here https://www.f150online.com/forums/sh...extender+blues , Can someone help me out and post some pics of the hardware installed on you truck with a factory bed liner. I would like to know what the finished product is supposed to look like!! thanks
Old Oct 23, 2007 | 12:00 AM
mc2912's Avatar
Anyone???
Old Oct 23, 2007 | 01:05 AM
Josiah's Avatar
I too would like to see. I have a bed extender but no hardware.
Old Oct 23, 2007 | 01:38 AM
mc2912's Avatar
Originally Posted by ChrisAdams
2 w707381-s900 bolts
2 W520414-S309 nuts to go on the two bolts. You would need these if you are putting the bolts into a non-SuperCrew bed. They go on the bolts.
4 YL3Z-84286A54-AA Grommets or rubber washers.
Cost on the bolts list is 9.24 each. Usually sold for 6.93 each.
Cost on the nuts list is 2.95 pair. Usually sold for 2.21 pair
Cost on the grommets list is 6.38 each. No dealer price handy.
Does anyone know if the W520414-S309 nuts is sold in a pair? cant wait to order the parts so i can put them on.
Old Oct 23, 2007 | 09:18 AM
07Redfire4x4's Avatar
I don't know if this will help you any, because I installed mine with a Dualliner. What I found though, was I could mount the pivot bolts through the liner (sandwiching the liner between the bolt's captured washer and the sheetmetal), but that didn't work with the grommets. I had to use a small hole saw to cut a hole in the liner slightly bigger than the o.d. of the grommets so that they would sit flush with the sheetmetal. I don't have any pics, but I'll snap some if that would help. Hopefully, someone with a factory liner will chime in.
Old Oct 23, 2007 | 12:31 PM
mc2912's Avatar
that definitely helps.. but i would still like to see some pics of the oem drop in bed liner... ordered the harware last night.
Old Oct 27, 2007 | 02:13 AM
mc2912's Avatar
Got my hardware.... still need some help ... can some please post a pic of the bed extender harware installed with a factory bed liner. i would like to see how the grommets/bushings are supposed to look. thanks
Old Oct 27, 2007 | 10:57 AM
Josiah's Avatar
How much did you pay for the hardware?
Old Oct 27, 2007 | 01:32 PM
mc2912's Avatar
46.96 but i only bought one of the nuts... i head read that there are two per part number. there is, but they sell them individaully. btw i got mine @ fordpartsonline... but tasca ford has lower prices and lower shipping. josiah any luck on getting pics of the bed extender and the liner? i will have to do this next week i will post some pics of what i got.
Old Oct 30, 2007 | 10:21 PM
mc2912's Avatar
i ended up buying the second nut at autozone... four for $2.
Old Oct 30, 2007 | 10:27 PM
mc2912's Avatar
top hole did not come out as smooth as i wanted... but it works.
i tried to put the gromets over the bed liner but it did not work... the ridges on the grommet would not catch the metal on the bed.... ended looking like this...
finished up
Old Oct 30, 2007 | 10:28 PM
mc2912's Avatar
with my daughters stroller loaded..
Old Oct 30, 2007 | 10:41 PM
Josiah's Avatar
Thanks mc2912. Can you list the part numbers again, I'm going to order as soon as you repost exactly what I need. It seems like you worked around not buying all the parts, which I am open to doing and finding what I need at the local hardware store. I'll obviously need the bushings and the bolts, but the washers I can find on my own as well as the nuts.
Thanks for your discovery, huge help! Pics are a plus! How solid is everything by the way?
Old Oct 30, 2007 | 10:46 PM
mc2912's Avatar
2 W520414-S309 nuts (can get these at the autoparts)
also two large washers for the backside...
like i said.. you can get the nuts for a few bucks at the autoparts store.. a lot cheaper...
Old Oct 30, 2007 | 11:01 PM
Josiah's Avatar
How did you get the nuts on the back of those bolts? And how much are each of those parts again or just a link to the website where I can search. I sound like a whiney bitch but I'm going to purchase now, thanks again you're such a big help.
