Vibration At Freeway Speeds
Old Oct 22, 2007 | 03:49 PM
etrevino103186's Avatar
Originally Posted by extremeethan
yeah I jacked my rear up and put it in drive too looking for wheel wobble or anything that could lead to the vibe, I dont know much about gears so I dont know if I pulled the cover if i would know if anything was wrong other then metal in the pan, the guy that put them in already put another set in and now has been less then help full I am just to picky and everything is fine
Well when my gears first WENT out I took it and the guy knew I had been driving it hard plus it was an OEM part and I had on open diff. Then when the noise started happening that was less then a year later and I told him I had been baby'in it and he had put a LS in. So he replaced the ring and pinion for free. I didn't see any vibe or anything wrong when I just jacked it up but my dad sat in the truck and would give it gas and you could hear a noise when you let off the gas. I'd say probably around 40-50 letting off. IF it is your gears whining they won't leave you stranded or break. They are just going to wear unevenly, and if you really get on it you may break a tooth bc they are wearing unevenly. That is the way it has been explained to me...
Old Oct 22, 2007 | 07:58 PM
Sal FX4's Avatar
I had the exact same symptons at highway speeds. Who installed your lift? Do you know if they installed the driveshaft spacer that fits between your driveshaft and the rear differential? Your Kit comes with one but my Rancho kit did not. I had to order one from Fabtech and i installed it and the vibration went away. If you have the spacer installed then i just wasted your time by letting you read this...
Old Oct 22, 2007 | 08:18 PM
extremeethan's Avatar
I did my lift, and what would make it all of a sudden come on? I though about that spacer a while ago.
