Lift blocks or AAL
Which is better? I already have a level kit on the front of my 06 FX4 and i already notice that the front sits a tad higher and im gettig ready to put a topper on it so i know it will sag a little more. What do you guys think i should do?
Originally Posted by titansu
Thumper,
I know you're a Gator fan - but your other sig chick was hotter.
I vote Block, Add a leafs do nothing to correct improper pinion angle due to uncreased hieght, they had stiffness that is uneeded, and when empty you'll likely have the rear catch air over speed bumps. I rep Superlift, and there is a reason that 99% of our kits come with Blocks rather than AAL's unless it's just completely necessary.
Blocks are cheaper and easier to do. I dont really haul alot of heavy stuff and dont want to change the way it rides now kind of stiff. Just was wondering if either way would work.
I actually think my ride is better with the AAL than it was stock. After I installed the front leveling kit, I always felt that the rear squated really bad when I hit the gas from a stop. This could be due to the 06/07's having 1 less leaf in the back. Bumps may be a tad more stiff, but the road feels smoother.. Hard to explain.
