Brighter Tail Lights
Old Oct 11, 2007 | 10:46 AM
  #31
ford2004F150's Avatar
Originally Posted by CANES676400
anybody
I can only recommend the VLED... your 3rd choice.
YES! They light up the WHOLE reflector in the tail light.
The difference is amazing!
Old Oct 11, 2007 | 11:49 AM
  #32
DTheobald's Avatar
Actually... not to go against the lights cause they are great... but i put one in the right side and the stock in the left side... same output... I liked it cause of the cool factor, but I think its the same brightness... now the 27watt ones i don't know, but the other 18led ones are the same output on the truck...
I am looking at brighter though... so I might just try some hella led tail lights or some ebay brand instead....
Old Oct 11, 2007 | 05:25 PM
  #33
CANES676400's Avatar
ford2004f150 i just sent you an email and thanks for the input guys
Old Oct 12, 2007 | 04:47 PM
  #34
dcamcofx4's Avatar
Originally Posted by ford2004F150
Don't fool with the resistor thing.... waste of time and money. Plus you'd cutting up the OEM wiring. Some resistors get burning hot too.
Buy an electronic flasher; plug it in right under the dash. (takes less than a min)
No hyper FLASH and no CRUSE CONTROL issues either.
which flasher should I be looking for?? I went and bought one, but still have the "hyper blinkers".
Old Oct 12, 2007 | 04:54 PM
  #35
Take that "thermal" flasher back...
You need a "electronic" flasher. Part number EP-27
thermal flashers won't work with LEDs
Old Nov 9, 2007 | 01:53 PM
  #36
willkr07's Avatar
I had the same problem. Installed LEDS on tail lights now I have hyper turn signals. How difficult is it to install a flasher?
