Need a key!
Need a key!
I received only one key upon my purchase and discovered that it has a chip in it which prevents hardware stores from making duplicates. Do I go to the dealer or a locksmith?
Originally Posted by Tbird69
You can still have them cut a key it just won't start the truck. I had one cut at Wallyworld to keep in my wallet just in case I should lock my keys inside.
I've been quoted from $40 to $120 for labor alone. it just depends on the dealer. I got a spare off eBay for $15.00 shipped. The dealer typically wants about $80.00 for the key itself
good luck. once you have 2 keys, you can program them yourself
when you look on eBay, alot of the people on there tell you how in the auction description. If I weren't so lazy I'd go check my owners manual. I'm 90% sure that the manual tells you how also
it's just a bunch of key on/off and then insert the new key
while you're there, you should also pick up a new key fob (if you've got keyless entry). eBay is awesome
