LED mirror turnsignal question. 2005
:help: Hola. My LED light bar has gotten nocked inside the plastic housing on the drivers side mirror. (2005) It still works but its pushed in about an inch or two on one side. Any idea how to get it back flush with the outside of the housing? Does the mirror come apart somehow? I have searched here but cant find anything that address this particular problem. Any help would be appreciated. Thanks.
man, not sure... might have to take the mirror off to get to it. i would like to replace my orange cover with red on my mirror~
chris |
See this thread:
https://www.f150online.com/forums/sh...d.php?t=301159 See MGDfan's post. This instructions are VERY helpful! :beers: :banana: |
Whoa! That was fast. Thanks! That looks like a mighty big job just to fix the LED's :lol:
Not really. Just pull the glass off, remove four screws and that's it. Like mentioned in the link, the LED is held in by plastic tabs built-in with the body of the signal. Sounds like yours has either come undone or cracked.
btw: the four screws are TORX but don't remember what size. |
XLTeaser is right, it's very simple to get off the mirror glass, there are 3 or four tabs that unclip behind the glass. Pretty easy to figure out. Once you get the glass off I don't believe you'll need to undo the four torx screws, you should already have access to the led signal at that point.
