No turning front rotors?????
Old Sep 7, 2007 | 12:07 AM
Booder, i can turn your rotors for free, and will install your pads at the same time if you'd like. Just PM me or call me
Machined rotors will last at least another 30k. Expect them to last about as long as the stockers originally did (with your driving habits), unless you have some super aggressive brake pad on them.
Old Sep 7, 2007 | 12:08 AM
-TXF150-'s Avatar
Originally Posted by redman_a12
So do you think If I lugged my front rotors up to my local dealership, they may be able to turn them for me?
No, they have to be turned by an on vehicle resurfacer...
Old Sep 7, 2007 | 12:10 AM
I had a bearing making a racket, the dealer told me it was the right side. $450 for each side, to replace rotors, $900 for both. I though it was the left side but bought one and replace the right side. Still had the noise. So bought another one and replaced the left. Fixed. Total of about $300 and about an hour and a half. The big problem is finding a deep socket, I think its a 59 mm.
Old Sep 7, 2007 | 12:12 AM
Patrick, can you turn the ones on the 04s and up? They have the bearing built into the rotor. When you buy a rotor, you are also buying a bearing.
Old Sep 7, 2007 | 12:17 AM
azmidget91's Avatar
rotorpros.com is 400 for a set of drilled and slotted and powdercoated, they help out soooo much especially at high speeds
Old Sep 7, 2007 | 12:21 AM
yah ive got access to an on car rotor lathe, well actually 3 lathes
Old Sep 7, 2007 | 12:22 AM
02XLT4X4's Avatar
You really don't need to turn rotors unless they are warped anyway, I just stuck pads on mine and called it a day when it started squeaking. 6 months later and all is still well, granted it isn't 04+ but still...
Old Sep 7, 2007 | 12:28 AM
you can still have the surface glazed over (looks like a mirror almost) and yah warping or uneven wear are another common problem.
-Patrick
Old Sep 7, 2007 | 12:20 PM
birdshooter's Avatar
Originally Posted by Quintin
Two wheel drive rotors have to be turned with an on-car brake lathe due to the bearing design. There is no way to securely mount a two wheel drive rotor on a conventional brake lathe, at least no way that I'm aware of.
Ok. For a minute there you had me worried. I replaced front pads on my 05 4x4 because of brake dust and had the rotors turned by a auto machine shop. Didn't realize there was a difference between 2 wheel and 4 wheel drive rotors though.
Old Sep 7, 2007 | 01:31 PM
redman_a12's Avatar
Dude you will eat up your new pads with bad rotors.....anyways.
Problem solved I found a machine shop that will re-surface them for $15 a piece off of the truck. Anyone in the Dallas area here is the shop name:
Plano Auto Supply & Machine
932 14th Street
Plano,TX 75074
Old Sep 7, 2007 | 10:13 PM
Quintin's Avatar
Not necessarily. If the rotor isn't heat checked or warped or anything like that, Ford says that you don't have to resurface them. Ideally, you want to minimize the need to resurface your rotors anyways...the more metal you take off them, the easier they are to warp later.
Old Sep 8, 2007 | 01:25 AM
Budha05STX's Avatar
Thanks for the offer Pat......I'll check them out and see what's up. I changed the pads about 12k miles ago. I'm pretty hard on the brakes being I tow a trailer when I work and my boat when I play.
I'll give you a call when it's time.
Old Sep 8, 2007 | 08:38 AM
redman_a12's Avatar
Also the dealership lists the spindle nut at $28 a piece, this same auto supply store carries them for $18.
