Got dynoed!
Old Aug 29, 2007 | 05:43 PM
HCFR-Halligan's Avatar
Got dynoed!
Went to the dyno today, primarily to check A/F ratios after the headers and AF1 intake. So here are the numbers, not quite what I was hoping for but it was hot as hell 96* F with about 46% humidity. Mods are as listed. Its hard to read but the A/F was about 13.3-13.5. Numbers are 244.69 HP with 293.09 Tq 1st run, 249.25 Hp and 282.95 Tq 2nd run. Just for kicks my cousin also ran his lightning we just put a 6lb pulley on and got 360hp and 490 Tq I believe.
Old Aug 29, 2007 | 05:45 PM
bud8817's Avatar
not bad.... for that heat.
Old Aug 29, 2007 | 06:07 PM
rsbeachbum2's Avatar
Where'd you get it dynoed at?
Old Aug 29, 2007 | 09:38 PM
ThumperMX113's Avatar
The torque number seems quite low.. The HP number isn't bad though.
last5oh_302's Avatar
Did you ever get a stock baseline pull before the mods?
Thanks for sharing.
Old Aug 29, 2007 | 09:56 PM
Dyno was done at Ramseys Performance off of Hillsborough Ave by TIA
I think the tq is low because of the headers and maybe a little too large of pipe but it sounds better this way now.
Never got a baseline sorry. Might give Troyer a call tomorrow see what they can maybe do with a custom tune the guy at the dyno said they dont get much more than 10hp over the canned tunes.
How big is the tubing?
I definitely agree that your LongTubes are killing your torque though. I can't believe as how much it is.
Old Aug 29, 2007 | 10:21 PM
Originally Posted by HCFR-Halligan
Dyno was done at Ramseys Performance off of Hillsborough Ave by TIA.
I DROVE RIGHT BY THERE TODAY!
Next time I'm over there maybe I'll stop by
Congrats by the way
Old Aug 29, 2007 | 10:36 PM
MGDfan's Avatar
That's a bit on the lean side.
I agree - you need custom tuning asap.
Old Aug 29, 2007 | 10:39 PM
I'm glad you saw this. The BoodLight didn't enable my brain to see this. .
I was running the same A/F when I was rocking the Edge and S&B. Custom tuning is in order, drive up to DeBary. www.VMPTuning.com
http://www.mapquest.com/directions/m...rough%20County
Old Aug 29, 2007 | 10:41 PM
Krohbar's Avatar
Heat, humidity sucks power. When I dyno'd last June, it was mid 90s as well, don't recall the humidity. Have Maggie SISO, K&N drop in, Troyer Perf 91 tune, I ran 247HP. Don't recall the TQ numbers though.
Old Aug 30, 2007 | 12:54 AM
Huitt24's Avatar
I ran a 255/290 with a K&N drop in and the pace setter long tubes on 87 octane.
what setting on the edge are you running? what size AF1 do you have?
Old Aug 30, 2007 | 12:58 AM
I'm guessing thats also with a Troyer tune?
Old Aug 30, 2007 | 05:33 AM
Huitt24's Avatar
no that was pre tunner. I had the 3.25 AF1 and Troyer tunes on order, they didnt come in yet. Unfortunetly I never did get it dynoed with Troyers tunes when I was N/A. But it did run alot better according to the old butt dyno
Old Aug 30, 2007 | 08:55 AM
How much did that custom tuning run ya Thumper? The exhaust is true duals 2.25 up to the muffler after the muffler i just had it changed to 2.5 up and over the axle dumped. I know this probably lost some torque but it had a horrible drone before.
