Is this a "fair" deal . . . ? [invoice enclosed]
10 hours labor for gear swap front and rear?
I can do the rear under an hour easy... 9 hours to do the front seems a little far fetched.
$539 for a tuner and a custom dynotune seems pretty steep also. Considering you can find these tuners for $300 new on the internet all day long... I would atleast buy that online and just have then dynotune for $100
I'm not familliar with the Diablo tuners, but ~$1550 for the gears installed w/ parts and oil sounds about average to slightly high.
As FatherFord siad, gears definitely are not a 10 hour job. Granted you have to remove the front differential and install the gears on a bench, but that shouldn't add more than an hour to the labor. The first time I ever installed a ring & pinion it only took me about 2 hours. I think 5 hours would be more realistic for a quote and still leave some extra time.
I'm only speaking off the top of my head here without checking first, but didn't torturekilla say the tuner was around $420? The tuner itself was around $320 plus $100 for dyno time, so he just included it all in one.
That price list is from the same shop, is it not?
Originally Posted by ford141
No, the invoice states $439 for the tuner plus $100 for the dyno tune. $539 and some odd cents total.
!Hijack alert: Gears here are $$ nuts $$. Five oh - any local recommendations? There's that perf shop on Sanatorium called 'Speed Products' (old converted gas station - does a lot of 'stang work, but I dunno - he's really young lol!)
bubba
Originally Posted by MGDfan
That IS too high... escpecially for a Diablo
bubba
bubba
If ya want, I'll see what kinda price I can get for ya from Kennedy Ford in Oakville. I have a few connections there. I tried pm'ing you the other day but I'm still too much of a nooB on this site and it won't allow me to pm yet.
If it's not Ford gears you're looking for, I have another contact (TAG Racecraft) in Oakville I can try for ya. I'm pretty tight with Mel (owner/racer), and he can get whatever it is that you need. Whether it will be a deal or not is another question.
10 hours for front and rear gears, that's cheaper than I'd do it for.
Originally Posted by Quintin
I'd pay good money to see that.
Yeah, no kid'n !!
Takes me an hour or so to swap the 3rd member in the 9" in my mustang. That's just swapping 3rd memebers and refilling. And anyone who knows anything 'bout racing knows the Ford 9" is the poor-man's quick change.
So, NO WAY he can change gears in less than an hour, LOL. Jack it up, pull the axels, remove the cover......nope, no way!
10 hours seems resonable with some extra wiggle room in case they run into problems.
I'm not sure about trucks, but when I had my Mustang re-geared in the rear, it took the shop 2.5 hours just to do the rear diff. Swapped 3.08's for FRPP 3.73's, had to correctly shim the rear, check pinion angle, etc..
The whole job plus Flowmaster install, and 3 dyno pulls with ECU tuning cost me $500.
I guess let me rephrase...
I can do it in under an hour if none to slight adjustments are needed. I think it took roughly an hour to do my 9.75. That driving it in, then driving it out.
I used to install gears on the side for 8.8 mustang all the time. Drive into the driveway and drive out in under 2 hours for $75. Most of the time it was right around an hour.
This does not include changing out clutch packs or what not. Reusing bearings if possible. If it was a full rebuild though, replacing bearings etc. yeah it does take a while. I just pulled the rear end out of the car for that.
What takes you an hour to switch out a 9" center section? Drinking a 6 pack while doing it? lol
