33x15.5 clearance?
Old Aug 21, 2007 | 03:22 PM
torturekilla's Avatar
33x15.5 clearance?
would a 3 inch body and 2.5 as clear these? i cant find a 100% answer on it
18x10 wheels mt classic locks
6 inch bs
12mm offset
Old Aug 21, 2007 | 03:24 PM
ThumperMX113's Avatar
It'd be like your signature, though.
Well when you had the ugly dating service up there.
Old Aug 21, 2007 | 03:25 PM
mSaLL150's Avatar
15.5" wide tires 18x10 rims with 6" of backspacing?? your gonna rub the upper arm soooo bad.
Old Aug 21, 2007 | 03:27 PM
????????? what rims should i be looking at then? what kind of bs ?
Old Aug 21, 2007 | 05:13 PM
PHS79's Avatar
For a 15.5" tire I would look for a wheel with 4.5" of bs, that way it will push the tire out and away from the UCA. With a 3" bodylift and a 2.5" AS you should be able to clear them without a problem. Heck you might, key word might, be able to clear them without the body lift if you can find the perfect set of wheels.
Old Aug 21, 2007 | 05:44 PM
LovetheTide's Avatar
This guy did it with just a spacer.
Those tires a SO wide in person.
Old Aug 21, 2007 | 05:50 PM
bud8817's Avatar
ya i was going to say all you would need is a small wheel spacer.... 15.5's are wide... and i love them!!!!
Old Aug 21, 2007 | 06:57 PM
so a 3 inch body, 4.5 bs wheel i should be ok ? i got some noob to intall the bl for 200$ lol
Old Aug 21, 2007 | 07:14 PM
PHS79's Avatar
Yea I would think that you would be just fine. But then there is the fact that 33's will look small on a truck with 5.5" of lift.
The pic that LovetheTide posted shows that it can be done with just a leveling kit and a wheel with the right specs.
If I were you this is what I would do. Either do the BL, 35's and Mickey's. Or just stay with your AS, the 33X15.5's and look for some different wheels.
Its too bad that we don't know what the specs are on the wheels in the pic.
Old Aug 21, 2007 | 08:36 PM
6 inch bs/ 12mm offset
Old Aug 21, 2007 | 08:57 PM
Bartak1's Avatar
Holy F*@K. 15.5, damn.
Thats all I have to say.
You sig makes me quiver all over. I cant stand to look at it
Old Aug 22, 2007 | 07:09 AM
bumfights
